Forgot to add these in my previous post. [Fiat Bravo 1.6 SX]
I've checked the oil level and its right to the max level on the dipstick. I thought it should normally be in the middle when the engine is cold? Is there any way i could leak some of the oil out from under the engine? Would this be good or bad?
Also the fuel cap doesnt seem to lock with the key. I have tried dozens of times to turn the cap then lock it with the key but it doesnt work. Am i doing something wrong or is the fuel cap lock broken?
The 16v engine on this car is very revvy. I only need to touch the throttle and the rpm jumps to about 4-5000. is this normal?
Another thing is the brakes on this car are so quick. I find that i am almost doing emergency stops in the middle of the road. Could it be all the pads and shoes have been recently replaced? Or is something wrong with the braking system?
The handbrake is also very tight as i mentioned before. Can only get one click on the lever and it almost feels like the cable will bust pulling that hard. Could this be related to the brake pedal being so responsive?
Let me know what you think thanks.
