A
azzwyatt
pioneer DEH-P7100BT bluetooth head unit,
Pioneer DEH-P7100BT Bluetooth CD MP3 USB Tuner with Voice Recognition and iPod Control
Main features: DEH-P7100BT
* MOSFET 50W x 4 Max. Power Output
* AM, FM Tuner (24 pre-set stations)
* Plays Your CD collection (including CD-R, CD-RW)
MP3, WMA, WAV, AAC compressed audio files on CD and USB
Your iPod, iPhone via optional CD-IU50 cable
Your USB device via a rear USB input
Other music devices via a rear auxiliary input
Music streams via your Bluetooth mobile phone
* Bluetooth Handfree Built-in
* Removeable front Panel
* White OEL Display Illumination (showing 2 lines with 16 characters each)
* Blue Button Illumination
* Rotary Commander
* Optional Remote Control (CD-SR120 steering remote available)
* Multi-Language Display
Connectivity
* Rear Aux-in
* iPod Direct Control
* USB Input
* IP Bus Control
* 3 x RCA Preout (F + R + SW)
Thanks to the RCA pre-outs, it is easy to expand your sound system. You can significantly improve your in-car sound quality by connecting extra amplifiers to your headunit. You could customize your sound system with separate amplifiers for the front speakers, the rear speakers and a subwoofer. Combining Pioneer 's EEQ+ with the RCA pre-outs let you create the exact sound you want, with the focus on complete flexibility!
Sub-display Output
* Hard-wired Remote Input
* Direct Sub Drive (+)
Combine the MOSFET 50Wx4 power amp and EEQ Plus technology to get Direct Sub Drive, another unique Pioneer technology feature. It enables you to amplify your front speakers by 2 x 50 W and add a 70 W amplified filtered subwoofer (in 2 Ohm mode) in the rear to enjoy outstanding full power bass without an extra amplifier. It's an easy solution for lovers of booming bass.
* 4V High Voltage Output
* Rear Aux-in
Bluetooth
* Built-in Parrot Bluetooth Module
* Handsfree Telephony
* Audio Streaming
* Voice Recognition (for English, German, French, Italian, Spanish and Dutch)
* Text-to-Speech (TTS) (for English, German, French, Italian, Spanish and Dutch)
* Additional Bluetooth Features Phone book transfer
1000 entries for up to 5 individual users (each entry can hold up to 5 unique numbers)
SMS alert system
External microphone included
iPod Compatibility
* iPod Ready via optional CD-IU50 cable
* Works with iPhone
* Compatible Generations (+) September 2005 onwards
* iPhone 3G September 2008 2.0
* iPhone November 2007 2.0
* iPod Touch (Generation 2) September 2008 2.1.1
* iPod Touch (Generation 1) September 2007 1.1.5
* iPod Classic - 120GB September 2008 2.0.
* iPod Classic - 80GB, 160GB September 2007 1.1.2
* iPod Nano (Generation 4) September 2008 1.0.2
* iPod Nano (Generation 3) September 2007 1.1.3
* iPod Nano (Generation 2) September 2006 1.3.1
* iPod Nano (Generation 1) September 2005 1.3.1
* iPod Video (Generation 5) October 2005 1.3.0
* iPod Click Wheel (Generation 4) July 2004 1.2.1
* iPod Dock Connector (Generation 3) April 2003 2.3.0
* iPod Photo October 2004 -
* iPod Mini January 2004 1.4.1
* Notes: * Pioneer cannot guarantee the future compatibility of our products with any iPod (or iPod firmware update) which is released after the Pioneer product release.
* The compatibility information is based on the above-mentioned firmware version.
* iPod shuffle is not supported. Only iPods with a "30-pin Dock Connector" are connectable.
* Supported Functions: Battery charging List browsing
Music playback (track up/down, fast foward, rewind, pause, repeat and shuffle)
Tuner Features
* Radio Data System (RDS) (+)
* RDS (Radio Data System) is a system for pro-viding information along with FM broadcasts. This inaudible information provides such fea-tures as program service name, program type, traffic announcement standby, automatic tuning and program type tuning, intended to aid radio listeners in finding and tuning in to a desired station. Note: RDS service may not be provided by all stations. RDS functions like AF (alternative frequencies search) and TA (traffic announcement standby) are only available when your radio is tuned in to an RDS station.
* Traffic Announcement
* Best Stations Memory (BSM) (+)
Best Stations Memory scans and memorises the six strongest, clearest stations available on each band.
* Auto Alternative Frequency Search
* Auto/Manual Frequency Search
* PTY Search
CD Player Features
* CD Text (+)
* CD Text allows various text information to be added to normal music CDs. By pushing the Display key, it is possible to scroll between disc title, track title and artist name (usable with compact discs featuring CD Text).
* MP3 Text Display
* USB Text
* Disc Title Memory
* Track Search/Scan/Repeat
* Last Position Memory (+)
* Last Position Memory automatically resumes CD play from the last point if there is interruption to CD play.
* Random Play
Audio
* 1-Bit D/A Converter
* Balance
* Fader
* Low Pass Filter
* When the subwoofer is connected and you do not want low sound to play from the front or rear speakers, turn the high pass filter on. Only fre-quencies higher than those in the selected range will be output from the front or rear speakers
* High Pass Filter (+)
When the subwoofer is connected and you do not want low sound to play from the front or rear speakers, turn the high pass filter on. Only fre-quencies higher than those in the selected range will be output from the front or rear speakers.
* 7-band Graphic Equaliser with 5 pre-set EQ curves and 1 custom
* ASL (Automatic Sound Leveliser) (+)
Compensating for additional outside noise, the automatic sound leveliser uses signal processing to automatically and electronically adjust the internal volume so that your music always sounds right.
* Advanced Sound Retriever
* Source Level Adjuster (SLA) (+)
Plug and play all your music from a variety of sources or stream audio wirelessly from your Bluetooth phone. The DEH-P7100BT is versatile and fully Bluetooth enabled. Once your Bluetooth phone is anywhere inside the car, you have full control. Make and receive calls and give voice instructions. An external mic (which is included) ensures that your voice is heard clearly at the other end, noise and interference-free. The DEH-P7100BT plays your entire music collection, supporting every commercially available audio file format. Hook up your iPod or USB music source via a dedicated input or portable audio player via the rear auxiliary input, and control them directly from the CD Tuner. You can control the system with its Rotary Commander, which works very much like a joystick essential for navigating through your WMA, MP3 and iTunes audio files. A large crisp white OEL ( Organic Electro-Luminescent) shows 2 lines of 16 characters each, so you can clearly see and control the content. The DEH-P7100BT also has 3 x high volt RCA pre-outs, so you can boost your in-car set-up with additional amplifiers, subwoofers and speakers.
EDIT put OT in title
* Rotary Commander
Connectivity
* Rear Aux-in
* USB Input
* IP Bus Control
Sub-display Output
* Rear Aux-in
Bluetooth
* Audio Streaming
SMS alert system
iPod Compatibility
* Works with iPhone
Tuner Features
* PTY Search
CD Player Features
* CD Text (+)
* MP3 Text Display
* USB Text
* Disc Title Memory
* Random Play
Audio
* Balance
* Fader
* Low Pass Filter
