S
Stephen
Right, I'm running the standard BT broadband router (BT Voyager 205 ADSL Router). My computer connects to the router through USB and my mothers computer connects through Ethernet. Now weve never had a problem with this set up but yesterday there was a power surge which unfortunately blew the power supply on my mothers computer.
She then went and fetched a new computer and set it up. Now the problem is it wont accept theres a router connected to it. If you unplug the ethernet cable it tells you that it has done so, so it obviously knows that it is connected to a router. The shop are being most unhelpful by saying that it isnt possible to connect 2 computers by USB and Ethernet to that router. It clearly is because thats how it came out the factory and I'm on the verge of inserting said router about his person.
I've tried every option to get this working but no luck. If you go into network connections theres a LAN connected with the correct IP and subnet etc for BT Broadband but its not connecting to the internet.
Help!!
Help!!
