Technical  Orange triangle (Tips)
tonnaf
Oslo
Hello everyone, i see alot of information about orange triangle showing check running lights, after checking with mes it comes the error below, any tips or information would be appreciated.
All lights and fuses checked and working properly, just i hate every time that i switch the low beams this triangle and error shows up 🤯😅. Thnxx again
Model
Fiat 500
2010
Boot lid open?
Key OUT turn on headlights check all side lights?
Turn off, start car, are drls working?
yes ,boot lid open coz i was checking the right rear lights conneciton for corrosion and test with multimeter the line, key off ok , after key on and switch from daylight to low beam ,,, buum this error again , drls working all other lights working :(
I had this very recently, kept getting the triangle light coming up followed by a message which didn’t stay up long enough to read it.
It was for the brake lights though, when the triangle came up I went to the back and sure enough light out, I lightly hit the cluster and light came back on
Replaced bulbs and been fine since, so I think my previous bulb was in the state of dying but not fully
Check the book or even the cluster where the bulb mounts, earlier cars have 10w type later cars only 5w, so if correct the car thinks there's a bulb out, (2×5, not 2×10)
I just ordered it and I will pick it up tomorrow since every store is closed today..y, I just checked it and from the manual it should be 10W, but the former owner did not take care of this, thank you very much for the valuable information
thnx for tip , in my case i think @John202020 found exactly the problem I have, let's hope after I get and replace with 10w this problem will disappear..
