Styling  Opinions on lowering....
under the bonnet....
Hello!
So I'm tempted to lower my car so I thought instead of buying the springs first and then see what I think, I thought I'd hop on Photoshop and mess about and see what it'd look like, heres my result :)
Opinions opinions opinions??? :D
Although I'm intending to go for 35mm springs so I don't it'd be that low on 35mm springs, unless I'm wrong?
Thanks!
Benny
pre-checks first
A - are your track rod ends in good condition? If No See B, Yes skip to C
B - Get 2x new track rods fitted - go to next step
C - Get the tracking done after the suspension has settled
Why?
lowering a car adjusts the tracking, as the wheels follow the suspensions movement, the tracking moves in a similar pattern
So lower = Scrubbing wheels = £££
Tracking = £ = Longer tyre life again
As for my opinions go very muchly on where you live
Lots of speed bumps? country roads? Pot hole city? Kerb parking?
Spine in good condition?
Ziggy
pre-checks first
A - are your track rod ends in good condition? Yes
Why?
Lots of speed bumps? Not too many
country roads? Live in a City and barely use Country roads ;) Pot hole city? here and there yes
Kerb parking? No :p
Spine in good condition? All good here (y)
Ziggy
Hows that sound? :)
Benny
You can try it by using lowering springs on the stock shocks but as the seals will operate on a different portion of the strut/damper rod, expect them to start misting within a couple of months.
Pay attention to the bump stops, or you may find yourself loosing it before you can say "Oh fcuk!".
care to explain misting? :)
thanks
benny
When the seals are a little worn (as opposed to completely buggered) oil from inside the damper tends to get blown out as a mist (often you can see this as a dark oil covering on the top of the shock) rather than as a jet (a very obvious leak). MOT folk will look for both, as well as doing the woefully inadequate bounce test (which just shows that there's some damping still going on).
The reality is that any damper will be well past its best after 40,000 miles, though.
Thought it might be that, but lets say shocks/springs were replaced say in 2009-2010 (obviously, well before I brought the car) how good would they be?
Benny
They'd be OKish. It's going to depend a lot on mileage and use.
I'd say experiment with the springs, see what it looks like. At least, when the shocks do fail, you'll have the tools and the experience to replace them (and the nuts and bolts will be reasonably free). GT 85 or Plus Gas at least a day before recommended. WD40 is pretty poor as a penetrating fluid.
Well I've removed a lot of suspension before haha just never on a punto :)
But thats, just like taking whole unit off and putting a new full unit in etc, so I know the basics of taking suspension apart like removing springs.
And for gt 85 or plus gas, motor factors or b&q?
Benny
thought you may be interested to know iv ordered some eibach sportline lowering springs for the mk2b, highly recommended apparently. I picked them over the fk street coilovers as I live on country roads ect and they are apparently very crashy and unpleasant with a "cheap" feel. Will put up photos when its done, and clean :p
