Well you either have a bad injector or the injector signal wire is going to earth
Your voltages don't make a lot of sense though. All the injectors have a permanent 12v supply and the ECU gives a reference earth to each injector to make it open. There's evidently something wrong with the suspect injector or wiring but you'd need to tell us where you are measuring your voltages, from what pins to where?
All injectors N70 pin 1 should have 12v when not energised coming through pin 3 on connector D81
Pin 2 should have signal earth from ECU. If this wire shorts to earth then injector will be constantly open
Have a look in Stilo Guides for help with injector voltages and resistance
I would check out voltage on pin 2 on the suspect injector. I'm surprised the ECU isn't putting out a fault code if injector is stuck open
