Looks like I'm going to have to change the front crankshaft oil seal on my 2004 1200 8 valve. It looks a simple job, but any tips would be appreciated.
I think the crankshaft pulley bolt changed pretty early on, maybe 2005-ish, and then stayed the same possibly until the end of FIRE production,
but its been a while since i took one apart.
From notes, an 04 used part 7766581 and an 06 used a 46778599, and the 46778599 was also used on the 500 at least as late as 2013.
Well spotted... i have 2 bolts listed in my notes for the 04 rebuild, so I suspect i had to replace the camshaft bolt too. If so, the other one was apparently 55192920.View attachment 484514
Oh dear that even more confusing it might be possible for the 1.1 and 1.2 to be different
7766581 appears to for the camshaft
Eper doesn't often specify left or right which is annoying
Elearn shows only specifying right for panda which we already know isn't correct
Do you mean it changed from right hand to left in2005.I think the crankshaft pulley bolt changed pretty early on, maybe 2005-ish, and then stayed the same possibly until the end of FIRE production,
The oil seal came today, it looks a bit on the small side to me but not having the old one off I can't make a comparison. The external diameter is 37mm internal is 26mm and thickness is 7mm all sizes are taken with a ruler.
