Jflores1410
- Joined
- Dec 22, 2013
- Messages
- 4
- Points
- 1
I have a 2012 500 sport and I've noticed every time I slow down or put my clutch in the oil pressure sensor will go on and then turn off quickly. What is the cause of this??
It's definitely not normal
Also, considering the fact that this is an American 500, oil pressure is even more critical as they have the multiair system to think about.![]()
This needs checking out urgently. I'd avoid using the car until you've ascertained the cause.
It'd be helpful if you could come back & let us know what the dealer says the problem is.
I know technology has changed but when I was building fast mini engines u used to take out the old switch as it was rated at 8 psi and swap it with an 20psi switch AND a mechanical gauge.
Im sure it will be a faulty switch.
IMO all cars should be fitted with a mechanical gauge. If the 500 was, we'd already be halfway toward answering the OP's question.
Fingers crossed.
Well if the OP checked the dipstick and reported there was plenty of oil on the stick then surely it would not make sense for there to be low oil pressure?
With sufficient oil in the sump, low oil pressure is indicative of a failing oil pump &/or worn bearings and unless attended to promptly, catastrophic engine damage will occur.
