Technical Oil pressure sensor. P0520
nazbrava
Hi all,
I just swapped the oil pressure sensor on my 1.3 multijet because i had the p0520 code. I swapped the senor ripped the code and then a week later it came back. How can I test the wiring to make sure there is no fault there. I tried a meter to check to see if I was getting a voltage at the plug and ground on the oil sensor with the ignition on but get no reading.
Model
Fiat 500x 1.3 multijet
Year
2018
