Technical  Oil pressue sensor
Duracell
Hi, I have been getting the min oil pressure warning coming up. It goes off after a while, I have checked oil level, oil cap now I have bought an oil pressure sensor but I am unsure where its located. I have a 2004 Idea 1.4 can anyone help?
Hi the sensor is close to the aux drive belt pulley my son's had rusted away and fallen apart I had to unscrew it with mole grips.
Hi
Thanks for replying but what is the aux drive belt is that near the oil filter if so will this require an oil change?
Hi it is close to the oil filter but you will not have to disturb the filter, put your hand on the crank/aux pulley it is little further to the front.My son's was so rotten it had fallen apart but is a quick job once you get the old one out.
