General  Oil leak
General  Oil leak
julielew
bolton
Hi After checking over the oil and water and brake fluid I have found an oil leak coming from under the electronic ignition coils on the front and running down the enging block. I have tightened up a small bolt underneath the coils but can't really see at the back of them. What could this leak be.
Hmmm. Thanks for this tip and advice. I have the same problem but the mechanic at the service said to me it must change the entire gasket from the top engine metal cover. (under the air filter) Probably they dont know about this O-ring. Is difficult to change this?
Thanks in advance
Thanks for that. I did change the coils last year. I will check this out and do as you say and tighten all the bolts up
Thanks in advance
#13 here
http://eper.fiatforum.com/eper/navi...INT_MODE=0&EPER_CAT=SP&GUI_LANG=3&WINDOW_ID=1
bracket is held on by 3 x m6 ( 10mm HEX) Nuts;)
fiddly to change ,:(
but I tend to remove the bracket, de-grease the parts,
add some sealant to the o-ring and metal mating faces and reassemble.
Charlie
