General  Oil cooler
General  Oil cooler
the ferret
nottingham
Hello all my oil cooler has a leak i have got it off with pipe work still attached,it is to far gone to be repaired,can i run car without one as was going to get a pipe made to just loop in and out of oil filter housing, it is a 1.9td estate.
1.9TD..??,
I damaged 1 cooler hose on my tipo 1.9 TD,
undid the good hose from the cooler ( tight/awkward) and looped it back to filter housing stubs,
YES will run slightly hotter. not an issue in December..,
Charlie
1.9TD..??,
Charlie
hello charlie thanks for reply,i will loop for now if i can get pipe off cooler,alu and steel fused together so not looking good ,there is a pirtex center in nottingham can get pipe made there if need to,need to keep old fiats going its a tempra 1.9td estate .
