Right, I'm considering fitting one after seeing the state of my throttle body. Well, when I say "seeing", I haven't yet opened it up yet but from looking into the open end of it there was a noticeable amount of the kind of gunk a catch tank could prevent. Think it could well be a contributing factor to the revving issue I've got the now as well as a slightly uneven idle.
Anyway, been looking into this and wondering what the best way of hooking it up is. Easiest seems to be pipe from crank case to tank then pipe from tank to induction but it has been said that this still means some of the gunk will get back into the induction/inlet. Some apparently just vent it to atmosphere even if this is technically(?) illegal.
Had thought about how else I could set it up without having a pipe feed back into the induction/inlet - maybe some sort of breather filter attached somewhere perhaps though I'm guessing as reading up on the different opinions and technical points had me going a bit cross-eyed at points :laugh:
