Oil leak Sump
Oil leak Sump
wigton - cumbria
Right people , i have a oil leak again ,,,
is there a oil seal were the crank attatches to the crankshaft pully or some sort of seal .. or could it be leaking from were my sump and block attatches , because soon as the Oil is warm i can have a puddle under my car with in 30 mins or so ...
From underneeth , were ive took that pic for u ming will post it up when i find my cable ...if you look towards the cam belt side u can loook up between the pully and the sump theres a little lip and i can see it starting to come down from there , , think ill have to investigate more while the sun is out , if it is the sump leaking , think ill get a new sump off egay and service my beast at the same time
yeh there is a large and small crank shaft seal. cant remember which side is whic h (think large is flywheel) but they can go and do need replacing.... pita to do in situ though
