Technical  OEM wheels and tyres
koalar
Distinguished member
Cheshire
Wheels and tyres work together, It's best to keep as close to original as possible
There is a difference between handling and grip, handling can't be assessed on a road you need to be at and passed the limits of grip
Banging a wider on any old rim will not always produce the best handling and stable car
Fiat go to the trouble and expence of altering the ET for different widths
ET41 155
ET38 165
ET32 185
ET30 195
Take just the spare space saver, fiat fit three different diameters in two different widths
There is a bit of leeway, but adding a wide tread to a narrow rim will result in more sidewall flex, more edge tyre wear. To some extent you can counter this by pumping up the tyre but it's a comprimise and the ride will now suffer
Hopefully I have caught all the auto correct errors every time I type R13 it corrects it to R14 for some reason
Fiat panda 100hp
6.5J x 15 ET30 195/45 R15
5.5J x 14 ET32 185/55 R14
Spare
4.00B x 15 ET 35 125/70 R15
Fiat panda 4x4
5.5J x 14 165/70 R14
Spare
4.00B x 14 135/80 R14
Climbing
5.5J x 14 185/65 R14
Spare
Cross
Spare
6J x 15 175/65 R15
Spare
4.00B x15 125/80 R15
Emotion
5Jx14 165/65 R14
Spare
4.50B x 13 135/80 13
Active. Actual, dynamic
5B x 13 ET41 155/80 R13
5J x 14 ET38 165/60 R14
Spare
Also worth remembering that fitting spacers, with appropriate length bolts, can also effect loading…once you go outside the parameters of the max size wheel and tyre combination
