Technical  OBDII Port
TJ07
"Spirito Di Punto"
Scotland
Can someone tell me how to access the OBDII Port?
I think its behind the little storage box by the drivers right knee, but I am unsure as to how to remove the panel to then access the port?.... Any ideas?
open cubby place fingers in the cubby feel upwards you will feel a cut out hole CAREFULLY PULL it will come away fetching the fog light switch bank with it... probably brake half the clips off at the same time a smear of grease on the tabs will make it easier next time
I have ordered a mini adaptor from eBay. Looking at the dimensions I think it should fit. It only sticks out by 2cm when in the socket, shall see when it arrives.
