Technical OBD2 interface 1.2 2003
HazyCosmicJack
Bristol
Hi all,
I have a Stilo 1.2 16v with the usual airbag warning issues and would like to know where the OBD2 interface is. I have been told its in the fuse box area by drivers knee but i just cant see it in there. Is there anywhere else i should be looking?
thanks
I have the 1.8 16v, but I think it's going to be in the same place, which is on the left side of the steering wheel, behind the fuse box cover.
Open the fuse access cover, you should see a tab press press on it which should make it possible to swing open the fuse access cover all the way down and show the fuses and ODB connector behind it.
In right hand drive Stilos, the diagnostic connector is at the top of the dashboard fusebox behind the drop down flap to the right of the steering wheel.
Thanks guys its where you said it was. I just couldn't see it. All sorted now and airbag light is now out.
Thanks again for your invaluable help
Kier
