Technical  Fiat stilo 1.2 unresponsive throttle
stilo97
Greece
Hello guys I need your opinion. I have a Fiat Stilo 1.2 ‘03 5 door we bought it new back then. It is a family car very well maintained with no problems until last wear. Out of nowhere the throttle stopped responding and the car stalled. The mechanic said it was giving fault codes from the throttle body so I change it with a used one. For 5 months it was perfectly fine. Then it started having irregular idle I once again went to the shop they took my battery off for some time reconnected it and it was good again. Some months later I was washing the car I took off to return home and the car went in safe mode rpm stack to 900-1000 and no throttle response again. I went to another mechanic he also removed the battery for a while cleaned a ground point inside the engine bay and the car was fine again. Fast forward 9 months from this it stalled again out of nowhere because of unresponsive throttle and the solution was again to disconnect the battery for a while. I have spoken with some shops that specialise in Ecu’s and they told me that it is a known issue for the 1.6’s ecu but not for the 1.2’s ecu. I will have the wiring checked and I hope to find something. Any suggestions about what may be the cause? Or anyone with the same issue ?
Thanks in advance and sorry for the long text. 🙏
Model
Fiat Stilo 1.2
Year
2003
Mileage
360000
It’s the f24…. Is it repairable ?
Can't really see
If that's a tear red arrow
Don't just solder the pieces together, yes unfortunately more dismantling
But some solid copper wire across, green line to add mechanical strength to the repair
If you temporarily leave it as it is. The car will work just no power steering
Are we taking the fuse box apart because the 5V was missing ?
Can't really see
No just to clean it
PI was wondering all the tests came back good wirring etc so can it be a bad fuel quality? Or failling camshaft/ crankshaft sensor?
It says it's not completing it's power on self tests
You often have to go through the relean when you disconnect the battery, learn the idle and end stop
Your saying it will not perform a relearn
Its a communication problem between the throttle body and ECU
It a faulty ECU, throttle body, wiring, power or ground, noisy or missing
The damaged fuse box will still work you just will not have any power steering
The first job is to try the relearn, needs testing again as connectors have been off, then measured the 5V reference
Be handy in a scanner as any spikes would show
hi again! After a short break due to bad weather i am back. So i bought a new elm327 because the last one was a chinese knockoff. It gave me another code P1689 (Oil pressure control solenoid circuit malfuction motorised throttle self compensation) with P1688 still present. I also want to ask why my radio loses connection to can everytime i plug in the obd reader?
I never seen them knock out the the radio before
It's fairly common to knock out the abs
Then again there's very few stilos here in the UK
Everything goes backwards and forwards on the same few wires, there a conflict somewhere, but I don't think it helps us
Can you see track 1 and 2 now with your new adaptor
saddly they are not supported. I will try will multiecuscan too. I am comming to conclusion with the new fault in mind that something is wrong with the voltages in the ecu.
