sometimes i wonder if it would be easier to buy a toyota
jug said:sometimes i wonder if it would be easier to buy a toyota![]()
TheCROW said:You are absolutely right... But then again Toyotas are for old people, we'll get one when we're old!! Right?
TheCROW said:Hanes Manual says: "The fan motor can be tested by disconnecting it from the wiring loom, and connecting a 12V supply and an earth wire directly to it."
So I think this should answer your question
Just make sure the wire connected to the battery is actually conducting the current ie. Check the fuse and the wire itself for any abnormalities...
Also check the earth connection the other one.
Hope this helps.
jug said:if the temperature still gets up to the red after all that i cant think of much else it could be, possibly a weak water pump, or a slight blockage somewhere. who knows maybe its just the temp sensor is faulty and when your gauge reads red its only really half way. i hope the problem is fixed this time mate.
jug said:the magic sensor? no idea, but fingers crossed it'll do some good
