Hi, trying to work out what's up with the Mrs 2003 punto active sport, we had issues with the steering light coming on randomly but it always seemed ok after switching engine off then on again.
I often had to put the battery booster on it to start as she was using only on short trips and not often, but was always fine.
Now it won't turn over, there is power in the battery, got booster on it too, when I turn ignition on, can hear pump, but it won't turn over at all, then there was a loud clicking noise from the fuse relay in engine, I found a diagram and appears to be relay r3, engine control relay, tried swapping this with r11 relay as it's the same but still does the same.
I've also noticed on the dash the light with they shape of a key with the word "code" is on and doesn't go off after a few seconds or does the engine management light with the rest of the dashboard lights.
Any ideas anyone?
Any ideas anyone?
