Technical Not starting
MM3
Skopje
I have a bravo 1.4 12v it stopped running for no reason i have checked and changed several parts including the spark cables injector fuel pump and when i checked the sparkplugs they were working. Fuses also fine both under the hood and interior. Fuel is coming to the mono injection but not running. I believe it seems the petrol is piling up a bit at on the injector. When i push the key it acts like it is gonna start sometimes but not starting. I also had some problems before like it was starting hard when i stop it and try to run again immediately when i wait a bit it was running without any problem. Also sometimes it was stopping at the idle mode as well as giving gas to engine. Those were not common issues i had but i wanted to mention maybe it may be related. Please help me with that if you have any information.
Model
Fiat bravo 1.4 12v
Year
1997
Mileage
200000
Coolant level ok..?
It was but i forgot to mention that the radiator was not working the thermostat of it changed and the radiator at the inside i dont know how to call it. It was also the time to change the coolant after the change i pushed the key to check and since then it is not running i did not disconnect any socket or anything i just release the coolant and filled the new one thats all
