Technical Not for the Squeamish! (Rusty Turrets)
Gun_Metal_Grey
:eek: Have any of you uno owners checked under the carpet in the boot area of your car? This is wot I found when I did, and believe me I thought my car would never see the road again.
Click Here!
Re: Not for the Squeamish!
can't seem to get the link up and running, but as i think i put on another thread, anything like these?
Hey thats a v good job.
Did u buy new panels or cut them off another uno?
Pete
ps gonna have a look at mine tom morn
Its a 1990 on a G plate. The first of the Mk2's. I think fiat had a problem with undersealing that year on turbo models! My sis has a uno 45s and the car's bodywork is immaculate! Same year as mine...odd. If only Fiat had build quality like the Germans, they would be a market leader.
Peterg: I bought the panels from a Fiat dealer, £45 each. Got a welder to fix them in place for around £70.
Nice job!
My Uno Turbo had rust on one side only. I discovered it when the carpet 'crunched' under my hand as I installed a speaker. Then I looked in the wheelarch and the sprayed-on coating was falling off in sheets.
I got it fixed effectively for free, since the car had a new WOF (MoT equiv.) when I bought it, and it shouldn't have had, so I claimed reimbursment for the repair, and got it!
-Alex
i wonder why it it the lower spec models are structurally so much better? my first uno was a 45s, a week after i bought it i got a jet hose and cleaned all the years of accumulated crap out of everywhere, pulled up the carpets and checked the lot, and it was immaculate, not a spot of rust anywhere, and that was a c-plate! same story with the 3 70sx's i've owned, it's almost as if fiat had something against the turbo!
btw the reality was far worse then the pictures suggest, i discovered the problem when i could hear a clunking noise from the back, when i pulled up the carpet i found what you see above, the top of the turret waving about, needless to say was not very happy
Gun Metal Grey, alright mate, mines starting to rust quite a bit but not as much as yours is!! my uno turbo is the same colour as yours and same year/reg!! spooky!
anyway, what part did you ask for from the fiat dealer? as i need to get mine done this year. its having a full respray inside and out hehe but need a few new parts
lemme know
Dunc
lemme know
Dunc
When I rang up Fiat I asked for rear inner wheel arch that supports the strut. If i can find the receipt I will post exact part number.
P.s. be prepared for hard labour, as the arch is spot welded all the way round, and is sealed with a special joint sealant! The spot welds need to be drilled out. Then the arch needs to be smacked out with a club hammer. Use a crow bar the lift the arch away from body and scrape away that sealant.
You must drain fuel from tank before welding and have a fire extingisher at hand.
I should of taken pics of when we changed the turbo on my uno...that was another nightmare.
