back again.
I don't appear to have any water at the rear wash wipe but the front works ok. is it fed from the same reservoir? or is there a separate one
definitely not frozen and I cant see any leaks, well not in the dark. I'll check again tomorrow.It's fed by the SAME PUMP as the fronts, and leaks are not uncommon near the rear quarter panel/rear seat, not frozen is it?
Hello again.
Yes, they're fed from the same reservoir. It's quite common for the pipe to split; you may find you have a damp patch somewhere in the car.
Thank You
Thank You
I have found a wet patch under the passenger seat so it looks like I have a split there. ?
there will be a length of trim down the edge of the sill,
probably Clipped roughly in place - then with added screws..
did it on my panda - here's the ePER view..
http://eper.fiatforum.com/eper/navi...3&WINDOW_ID=1&SGRP_COD=23&SGS_COD=0&DRW_NUM=4
there will be sound deadening "underlay" under the floor mat / carpet..,
it'll be soaked ,
I carefully / cut / tore the bulk of it out and let it "drip-dry"
Charlie
