No power to my new Parrot RK8200
markmcrobie
Serious help please - I can't get my RK8200 to turn on. I removed my Fiat standard stereo from my 07 Grande Punto, and connected the lead to the Parrot's ISO lead and tried turning on - nothing. No matter if the engine is running or not, I tried pressing every button on the parrot, holding them in, etc, nothing.
I looked at the Fiat's leads and compared it to the parrot's ISO connector, and found that the black lead from the parrot was matching up with black lead from the Fiat. Fine. I then noticed the yellow "ACC+" lead from the Parrot was matching up with the red/white power lead from the Fiat. I also noticed the red "Battery+" lead from the Parrot wasn't matching with ANYTHING in the Fiat, i.e. it was lining up with a blank space in the Fiat's connector. So, as per the manual, I tried swapping the yellow and red leads on the parrot ISO lead, so that now the red/white lead on the Fiat marries up with the red "Battery+" on the Parrot. Nothing. No matter if engine is running nor not, no matter which button I press, nothing.
I tried re-connecting my old Fiat stereo (just to make sure I hadn't buggered the Fiat's wiring when removing the old one), and it works fine still.
Tearing my hair out here, I've been waiting MONTHS for the RK8200. I'm do disappointed I could cry!
calm down, theres nothing to worry about here. its simple. your car does not have an ignition feed. you will have to have your stereo on a permanent live or manaually get an ignition feed from the cigarette lighter etc.
to get it working for the time being. see the wire that is connecting to the wire beside the black wire i presume, its the live one (red/white). join both the red and yellow wires together so that the feed coming from this goes to both wires allowing your stereo to switch on manaually. that should sort it for the time being
Thanks. How?
This sounds complicated!
Cheers. How will I managed to get the red & yellow from the Parrot's ISO lead joined into 1 single wire? I notice they each have spade type connectors half way down them, covered by clear rubber (presumably to make it easy to swap them). Would this be the way to join them too? I don't wanna go snipping wires if I can avoid it.
Is there any disadvantage to the above stop-gap method?
Thanks a lot mate
Didn't work :-(
Using an electronics tool kit I joined the red and yellow wires from the Parrot's ISO leads together and made sure they then both went in to the Fiat's connector to line up with the red/white power lead. Nothing. No power to the parrot at all.
ArrghhH!
its not that complicated but as monty said if you dont know what your at leave it and play it safe. right check that this red/white wire is you live wire. multimeter would be the best way. joining the ignition onto this will have 12V running down both lines so the stereo should work. i think theres a small blade fuse on the rear of that unit. make sure its still intact
j0nny thanks a lot for the tip! I even subscribed to the forum just to say thanks!
Reviving an old thread here but I was going crazy trying to install my Parrot MK6000 on my Grande Punto 2008. Even though it was not the same Parrot model discussed here I supposed I could give it a try since the Grande Punto connectors should be the same.
My Parrot wasnt turning on either. And what I did was find a 12V ignition source and plugged that into the 12V Battery connector on the Parrot. A picture says more than a thousand words so:
9427932213
[ame="http://www.flickr.com/photos/divanus/9427932213/"]DSC_0193 | Flickr - Photo Sharing![/ame]
I had to swap the fuses wirings as the manual says for it to properly work.
Thanks for the tip again!
Regards.
