Reggie2707
- Joined
- Aug 26, 2012
- Messages
- 5
- Points
- 2
Hi all
We have a JTD diesel with major probs at moment, firstly the car is as flat as a pancake on initial start and wont go higher than 3000 revs, car pulls back, then if you are going down hill all of a sudden car will kick in and runs fine, then there comes a bad smell through the vents then antipollution/engine management light comes on.
If the car won't go faster than 3000 revsm if you stop car give it a min, the start it and boot accelerator it will rev all way around the clock to 5000, then car runs fine but still with this bad smell of fumes!!
We think we have cleaned EGR (and think/hope) this is connected to big black hose that runs to front of engine/radiator???? As it was filled with gunk and once cleaned out it took it for a run and boots great, but then next morning flat as pancake no power at all?????????
Also if you stop car you can here like a pumping noise coming from under the car, when you look the pumping then gets faster and then a pile of smoke pours from the little mini exhaust ??????
Any ideas would be appreciated.
THanks Jane
THanks Jane
