General  No Low Compression
Mark 123
I have a 2004 Fiat Stilo 1.6 16v Multi with very little compression on cylinder 4 so I take it one of the valves has gone or the piston has a hole in it . So I will be replacing the engine , will a 1.6 16v out of a hatch fit a multi wagon and will the gearbox be the same with it being an estate.
Have you tried just changing the head gasket, that is more likely than anything else and alot simpler than a transplant
