My handbrake went earlier whilst Christmas shopping... not like when the cable snaps, there is still tension and it clicks when pulling it up it just doesn't stay there....
Ideas?
Ideas?
Oh you poor thing, just as you'd got the clutch fixed.
If the lever does not stay up when you let go, the ratchet inside the lever is worn, or not engaging properly.
If worn, whole lever needs replacing. I've tried to look on ePER, but it is not willing to play right now.
Is the button popping out fully? Sometimes it can stick inside the grip, so the ratchet pawl does not engage with the teeth properly.
Do you normally lift the lever without pressing the button, or do you press button, lift lever and release button? The first method will wear the ratchet teeth, although this is now the method recommended by the manufacturers, not because it is better, but because it reduces claims against them if the car fails to stay put. Pressing button as you lift is still better for long service life.
Replacing the lever is not too difficult, once you've gained access to it, past the seats and any centre console in the way.
I carry a chock of wood through the winter as I can't use the bloody handbrake because it'll stick on!
I've got my own ePER on another machine, from June 2012, and this lists 5 different part numbers.
The model year, full VIN and whether it has vehicle dynamic control, disc or drum rear brakes. (Do I remember its drums from another post?) And what model, SX, ELX, Active, Dynamic.
Don't post your VIN on here, send me a private message. I'll look up the part number, then we can see if any are available on eBay or elsewhere.
Thanks for the VIN.
ePER has now revealed that up to the 2006 model year there were two levers, one for drum rear brakes, the other for discs. From 2006 there was another different part number, but that should not worry us.
Part number of the lever is 735266643. 18 months ago it was £110, so would be a little more now. At least that gives us a guide.
This one looks good. http://www.ebay.co.uk/itm/FIAT-MULT...0-BREAKING-HANDBRAKE-LEVER-ONLY-/390662508037
Ask them to confirm drum rear brakes and grab it quick.
Or this one. http://www.ebay.co.uk/itm/FIAT-MULT...ts_SM&fits=Model:Multipla&hash=item46140e2ea4
Ask same question, although I think both should be drum brakes from their spec.
Good luck, and have a good Christmas.
That's a different issue. Water getting into the cable freezes. I think there are threads on here somewhere about that.
I know why it does it, I just thought it may help Hastings until he gets his fixed.
I live in a hilly town so leaving in gear wont hold it.
Where there isn't a kerb to turn the front wheels against. I chock it.
Can't wait for march.
