No electrics - help needed
A
adel
hello everybody, iam facing a terrible problem, the car is not staring, there isnt any electricity into the sparks and their leads. the battery , starter are fine.
but last day i washed up the motor, but it works normally about 5 hrs, then i picked off the air filter and it ran great..
then at night when i was speeding, it sounds like there isnt any fuel and it turned off..
so plz guys , what is the problem and how can i start the engine, thanx a lot
*title added*
Re: Untitled
Sounds like it could be just the fuel cut-off switch...(are you sure you have no spark?)
Depending on wether you have a mk1 or mk2, its either a button under the seat (mk1) or behind the passengers kick panel (mk2).
Daz
Free X-box 360! All you have to do is register and send to friends, not a scam!...
http://www.consolegrab.co.uk/?r=16309
thanx daz
1st the button is under the seat( by the for what can we use this button)
2nd , i picked up the spark lead and put it on the enginesurface , there isnt any electricity.
so there isnt any electricity reaching the combustion chamber. its 1.6 1996
Re: thanx daz
Does the code light go out on the dash?
"i washed up the motor"
Please explain.
Re: thanx daz
i'm more worried about this "..i picked off the air filter and it ran great"
:S
Re: thanx daz
it was so dirty, i took it to the car wash!!
Re: thanx daz
my friend, saturday morning , i took my great bravo to the car wash , and i made a complete wash ( body, motor..) ok??
and every thing went great.
then, afternoon, i picked off (removed) the air filter,then i made arun, it wnt also greater..
then at night,i was speeding then the (like there isnt any fuel or elctricity then it goes. after 15 mins, i parked my car . after 2 hrs i tried to start the engine, but there isnt any body till the moment.
what i relized after all my tempts,is that there isnt electricity reaching the sparks.
Re: thanx daz
yes i washed the engine with waterand detergents
Re: thanx daz
You probably shouldn't use water in the engine but...
A similar thing happened to me when I hit a massive puddle in the road. Water got into the electrics around the spark plugs and the car wouldn't start. I called the RAC out and they used compressed air to remove the water and then it was fine.
Try and dry as much water as you can and try and get the car in a warm ventilated place like a garage. It should be fine if you leave it.
My Member Page
Re: thanx daz
ur idea sounds great, but my friend it ran great directly the motor wash for 7 hrs!!!
so if there is any water in the electronics it should dried. right?
Re: thanx daz
After I hit the puddle I still managed to drive home and it was fine. It was only the next morning it wouldn't start. I'm not sure how long it would take to dry as I had help. But I think it would take a few days.
My Member Page
slightly random request
but can someone add a topic plz?
Buzz (formerly LightWarrior)
The champion of the Bravo 1.4
Owner of the Bravo 1.8
Member Page
Re: slightly random request
guys, i took it for a diagnostic approach.
they found that the cranck sensor was faulty. it cost me about 120$!!
I
845
IMC63
I
C
2
823
K
N
2
433
M
S
2
631
Dark Lurker
P
1
289
Andy1.6hlx
A
