Technical No bass from left front door main speaker
Panda500
Antwerp
Dear 500L users,
Concerning my 'new' 500L (the 2018 one, not my classic 1971 one), I notice since quite a while that the lower speaker in the front left door does only give high frequency tones and no low ones. The little high frequency speaker at the door handle does it OK. And the lower 'main' speaker does give high tones as well... So no cable interruption I guess. I checked the cable connector at the door hinge, disconnected it and sprayed with contact cleaner, but this did not change a thing. I was surprised by the number of contacts in that connector. Almost about 20 or so! All other speakers work fine over the full frequency spectrum.
So I'd liked to check the cable at the radio side. But how do I remove or open it? Or other ideas about the origin of this phenomenon? My 500L is the 'Connect'-type of car, with the 7" display. Kind regards, Frans
Model
500L 'Connect' - 1398cc- 95 HP
Year
2018
Mileage
47000
There were a number of videos describing how to get access to the head radio unit. It's rather simple, you just need a plastic instrument (some of them using credit cards too) to release the plastic cover around it.
Also, it would be helpful in your case to find 100% good speaker and to check with it, as you can connect via door-body connector. The same way you can check the original speaker too using the other part of this connector and 100% good sound signal.
