edbremner
My little cinqi has really been having a ton of issues recently.
Reckon it serves me right for increasing the 'expected mileage' on my insurance!
Replaced clutch and new one broke within a few thousand miles. Got a replacement (thanks Big Mick) and fitted that, only for the gearbox to die. Replaced that, pleased that now getting the job down to under a day.
Had some 'missing' issues, changed crank sensor and cleaned up leads and that seemed OK, but now the immobiliser has gone awol.
The Car
P reg sporting 1108
So, symptoms are:
For a long time the code light had intermittently gone on and off, but it never seemed to be a problem, the car always started, sooner or later
Then, had codelight on solidly and car immobilised, no pump, no spark.
After cleaning all contacts on immobliser box/relays below ECU, no luck....
so replaced: ECU/immobiliser/key/barrell and car would then start fine and as far as I was concerned the problem was solved. 7-10 days later, the problem has returned.
So can only presume that there is some other unknown issue which is causing the immobiliser system to error/break/fault and stop it clearing.
have tried disconnecting battery, but not sure this has been for long enough to allow ECU capacitors to really die and force it to reset??
Next steps
OK, where to now. There seems little point in replacing ecu/immobliser/keys again as suspect would only happen again.
Any ideas what other issues might cause this?
Others have suggested ( I do read the archives
Replacing the ECU chip: Some suggestions are that this will help, but others not so sure. I have asked the guy in Israel selling chips about this and he has said that the immobiliser code is kept in two chips on ECU and changing the main one may or may not fix an immobiliser problem. Any thoughts?
What ECU chips are available at moment? Am I right in saying Gazzaman is no longer about? Are McCritch chips available still. Can anybody confirm that the McCritch chip will immobilise the immobiliser?
Does anybody else have any ideas at all in what other route forwards to take?
Would it be worth considering swapping bits/all of the wiring loom?
Any ideas would be really appreciated as I am close to being totally stumped on this.
Biggest thanks in advance!
eib
The Car
P reg sporting 1108
So, symptoms are:
Next steps
- checking the sender around the key barrel. I have looked at this, it appears to be there and working? But not sure how to remove? clues?
eib
