Grande Punto Newbie
Grande Punto Newbie
Royston3737
Hi everyone, two problems occurred this week 2009 grande punto media player not recognising memory stick and drivers door window and mirror adjusting switches not working!
Media player may require update or fault with convergence node or a proxi alignment might be needed.
Might be fault with switch if windows and mirror not working. Have also seen broken wires where loom comes out of door into body.
As has been said, check the wiring where it passes from the door to the body. Also check the underside of the switch, the wiring plug has been known to come away.
As for the media player, try another USB stick, one of my sticks won't work for no apparent reason. I also think larger capacity sticks give more trouble.
