Hey everyone
I'm Stu from Malta.
New to the Forum and indeed new to Fiat's (I was never brave enough to buy one before)
as i was always told FIAT means Fix It Again Tomorrow
I recently bough a Punto 1.2 16v ELX from year 2000, It was owned from new by an old lady and has covered only 11k miles, so as you can imagine it's almost like a new car with hardly any wear and tear whatsoever.
There were some minor issues which were all related to lack of use, such as window mechanism and adjustable mirrors seized, HT leads old and perished, etc but these were easily fixed.
The car was driving great, just like driving a new car.
Now I have a problem, and no idea what to do.
Last week I opened the car and the central locking was not working, When I got inside and tried to open the electric window, this also is not working, Then I put the key in the ignition and the fuel light is flashing and gauge shows empty, The engine turns over but will not start, I have checked all connections to the BCM, checked fuses, Checked the antenna ring around the ignition, and everything seems ok, no damp, no corrosion or loose plugs / wires. also checked earth points to ensure they were also good.
Yesterday I noticed that the right hand indicator lights were all illuminated, but not flashing, I disconnected the battery, and after reconnecting today, they had gone off.
I'm sure this is a fairly common fault, but I have no idea what should be the next step, Is it a case of replacing BCM / ECU etc as they are all coded together, or can it be fixed with some diagnostic software ?
I'm Stu from Malta.
