Blonde?
I'm very grey and very thin on top!
Ok, I'll get into 4th and slow right down to 1000rpm(?) and try and accelerate away.
Maybe not tomorrow or Wednesday, but by the end of the week. I don't drive every day, but next time out I'll try it.
Actually, I was out this afternoon and I carried out an experiment a few times.
As I said, there aren’t many flat places around here, so I had to make do with what I could find.
Remember, ours is a 500TA 2001 Euro5 and without a DM flywheel.
Slowing right down in 4th gear to 1000rpm, I floored the throttle. I did this a few times on different bits of road on slightly different inclines but got similar results. I also slowed to slightly above 1000rpm and slightly below 1000rpm. The difference in the revs were the thickness of the rev counter needle. How accurate the rev counter is, I ain't got a clue, and how accurate I carried out my experiments, I cannot say, but I did it as well as I could.
Results?
I can honestly say that flooring the throttle in 4th gear seemed quite normal and I would have expected a small engine to react. It vibrated a bit, and then went on without complaining and accelerated away quite well. The vibration wasn't harsh or alarming, the car didn't vibe off the road, or make some awful grorching noise.
If I tried it a needle's-width below 1000rpm, the engine did not much. I vibrated and struggled and nearly stalled. A needle's width above 1000rpm, the engine didn't vibrate at all and accelerated smoothly and evenly.
The 1000rpm barrier is crucial to smoothness and power. Below and it can't do it at all, above it, and it's fine, and smack on it thinks about it but is ok.
At no time did the car feel as it it was under torture or seem to vibrate itself to bits.
Thanks and regards,
Mick
