General New Member, Uno Cento
bouval
Greetings Fiat land!
I am new here and would like to intro myself
I own a green 97 Uno Cento. My children affectionately named it Snot and its nickname stuck :rolleyes:. Snot is my second Uno, I had a real gem of a modded Uno Fire in my university days. Hopefully Snot wont stay to stock for very long either. I have some ideas for the interior and wheels :idea:
Hi Alex
My Uno is actually metallic green, but you have to love a child’s mind. Anyway, Snot should be back from an engine replacement this week. I upgraded Snot’s 999 to an 1108. And 10hp if I remember correctly.
My red varsity Uno’s mods:
1.2 Mpi engine from a Fiat Palio
Palio dials and aftermarket tacho
15” Wheels and 195/45 15 rubber
Autostyle grill
Custom hood
Custom exhaust system
Huge Sound
40mm drop all round.
The 1.2 was good for around 170 kph on the 1108 gearbox.
I won’t go that route again with this Uno. I am too old for bleeding eardrums, bruised kidneys and speeding fines. I plan on 13” chrome wheels, and some cowhide on the seats. The interior needs some tlc. Maybe some ICE, window tint…
How about 14" Maserati Biturbo wheels. ?
@ johorridoh
Sweet.:yum:
Those are the biz mate, pity they are not 13's though.
Snot is still in the workshop :(. I miss my car. Anyway if I drill into the metal of the car, what is the best way to prevent tin worm aka rust? I got a sweet audio unit as a gift from my family:D. I need to get +12v into the cabin and have to drill throug the firewall. The Cento model is super basic and doesnt have an audio harness. Any help is welcome
There will 100% be a grommit in the bulkhead already where the loom goes through or the throttle cable, you do not need to drill anything, or just get a feed from something inside the car, on the mk2 uno's in the uk the basic looms had the connectors for things that were on the bettermodels so you may fine a plug with a +12v feed inside the cabin somewhere.
Dan
Thank you for the info Dan
Snot is back from the shop!!:)
The 1108cc sounds very good. Pulls nicely too. I will post pics tomorrow after Snot has been washed. :eek:.
Here he is. Ladys and gents introducing my Uno Cento, Snot!
I did some breakers yard diving yesterday. Spot the difference
Nice
Did someone say Wall-e?
Green wire goes to.........uhh??:confused:
Nice one Dan. Thanks mate
Ashtray cover prepped for surgery
After surgery
Yikes! Uhhhh green wire does what?:eek:
All better.(y)
Nice one!!:slayer:
Yes just like EssexUno said, I found +12V and GND on the fuse box in the cabin. Just imagine all 6'3" of me behind the dashboard :D. The dial kits only had about 200mm of wiring loom, so the soldering was a real pain. The white wire from the engine bay is the tacho pickup on the coil negative.
These door cards are in a bad state. Most of the plastic retaining clips on the driver side is broken or missing. I can see the inside of the door when it is closed. :eek: The passenger side is no better.........
Another beer and few minutes later.
Uhh....a bit messy:eek:
15 years of use made the door cards very dirty:eek:. The new vinyl was a gift from my wife:yum:
Time to prep the cards. The old plastic is removed from the cards. The smooth side (old inside of the cards) will be covered, see next pic. I cover all the holes with some heavy duty tape.
The lines on the cards are where the old plastic was attached. The new vinyl is glued to the old inside of the cards. The vinyl will show absolutely every imperfection, prep well!! Leave at least 2 inches of overlap... and use loads of contact adhesive...
A couple of hours and some very sore fingers later. Some advise here, beer and contact adhesive fumes does not mix together well......:spin::nono:
The next day.
I test fit all the cards. note the small exposed area on the right that the old plastic used to cover...
Sweet ass:slayer:
The parcel shelf has been hit hard by the sun.
Some cheat spray:eek:
Not bad....
Snot is high!!:D
Ha Ha
Some exhaust mounting hooks were made from bolts. I found some broken rubber exhaust mounts as well. FIXED:slayer:
It was a busy weekend for Snot
The workshop techs busy dismantling the doors
Time for window film!! I chose 35% VLT still legal in South Africa(y)
Done, great job.
The tint is great but those wheels are bit off...:eek:
Sweet. I got 13" wheels with 165/65 boots
Snot with his butt in the air:). New 40mm lowering springs ready to go. The car sat to high on the stock springs. Then my mobile battery died:mad:, sorry no more pics of the springs install.
Looking good Snot old boy.
Some brag pics. Rock star!:slayer:
I know it has been ages since my last update......... my apologies :eek:
Anyway here are a few more mods I did
Old Snot's interior was stripped...
This is hard work.... :p
And messy...
The seats were re-upholstered... looks great!(y)
The roof liner got the same spray-can treatment as the parcel shelf
Power windows!
Nice kit... everything needed is included
The winding mechanism is secured with self-tapping screws
The ashtray came out again for more surgery.
My improvised plastic hole saw. Ha ha. It got the job done...
The switches sits snug on both sides of the tachometer and clock
Time for some speakers.
Sub box and the 6x9's
I made some brackets to hold the 6x9 boxes secure in place
I made rear speaker mounts from some cutoff timber pieces
But the result is OK
6" mids.
Time for a new Steering Wheel
I had this red one from my old Uno.... but the color wont match Snots new black interior.
After an hour or two of sanding and rubbing....:rolleyes:
Masked of.....
Then I noticed that my new steering hub adapter does not have a proper grounding point for the horn. $%&#@( piece of cheap #*@$#..... OK new plan. The horn switch will move to the dash next to the steering wheel.
The basic diagram of the horn system on a Uno
The brown/blue wires, will be connected to the steering wheel horn switch
The steering wheel is installed after a few coats of paint.... not looking to bad...:p
