Technical Uno 1.4 Big end bearings
Rashid123
Chatsworth
Need help with 40thou big end bearings for my uno turbo 1.4 ,any suggestions where can I get a set,thnka
Is that the size they are already?
As usually around here if we have a crankshaft ground the engine reconditioners supply the bearings to match, mainly so if they don't match it is there fault;)
I had an Austin Mini 1000cc years ago that the crank grinder messed up and had to order specially a set of +60 thou. bearings, luckily it did the job.
Yes it has 40thou already
Use forum eper to find fiat part number for size you want. Then Google the fiat part number.
Or ask an engine machine shop if they can find the parts , machine shop likely to know suppliers in SA.
Good luck
You are getting help from the forum.
How about answering question on this thread?
