Technical New JTD diesel fuel filter improves economy?
Argonought
It's about GO! not SHOW!
POOLE, Dorset
There's been a recent post to suggest that changing the fuel filter has made quite significant improvements to mpg on a JTD
Now, I can easily understand how performance might be improved but I simply can't work out how a new filter might improve economy. There doesn't seem to be any supporting evidence on the web either.
On the hand if there's any truth in it then it's a very cheap option :idea:
Anyone have any experience or opinions of this?
my economy was on a slump so i was hoping that a full service would cure it.
an air, oil, fuel filter later..........
no change :mad:
It can make a difference on some cars. I know on derv Nissan Terano's and mavericks, clean the fuel filter is the usal way to stop smoking/ poor economy and low power. These do however have a mechanical pump and are not common rail. It is something to do with a slight imballance in pressure between the feed and return diesel pipes from the tank upsets the pump.
My stilo is giving slightly lower MPG than I think it should (41mpg average ) so I am going to change the filter just incase and see what happens.
Well done (y)
I'm sure you'll find a cheaper filter than me too ;)
Back round the corner to the motor factors at lunch time. They probably wont have one in stock, but will find one and have it for me by the end of the day. They are a small local company, give very good service and have good prices too.
How do you go about changing the fuel filter in a JTD? Am I right in thinking fuel pressure has to be released before unscrewing the old filter?
How would I release the pressure? Start the engine and pull out the fuel filter relay/fuse?
Regards
Dave
Fuel filter in on the low-pressure system. Just unscrew it.
No pressure to release. It is a messy job and you will spill diesel everywhere. I found it easier to disconnect the pipes, undo the 2 bolts and take the filter mounting off with the filter, then separate them out of the car. The water sensor on the bottom of the filter is much easier to get on/ off with the whole thing lifted out.
And what about clearing any air in the fuel system? Is that bled using the drain plug on the base of the filter?
Regards
Dave
Regards
Dave
No, just leave the key on for a minute before starting. The pump should clear any air out and refill the filter. you may get a couple of rough starts or it may stop after starting due to an air bubble but it soon clears.
OK, thanks for that. I'll let you know how I get on :)
Dave
This is so unlogical that filter changes mpg at all... It might cause issues, but I'm not sure that it can improve anything.
this is what the garage did when they replaced mine. (y)
