Hello,
I am looking at buying a FIAT PUNTO DYNAMIC 1.3 MULTIJET 90 (5 door), 2006/56 reg plate @ 77,000 miles, full main dealer service history . I really like the car.
I have been to have a look at the car at the dealers (independent)
I have a few concerns and wanted to check if its just me being stupid. I am newbie to car buying, not just fiat, so please bear with me.
Hope a Fiat owner with the same car can advise me.
1. The dealer has advised me that the car does not have a cam belt or timing belt. It has a lifetime chain so no replacement is needed. Is this correct?
2. Opening the bonnet, there is a belt visible when looking down towards the left (driver side). Dealer said this was the fan belt. Is this correct?
3. The car has a problem opening the nearside back door from outside. The door had to be lifted slightly before it could be opened easily. The door is sticky.
4. When you turn the ignition half way all dash board lights come on and go off. But the engine light stays on. If you start the engine, all lights go off. Is this normal?
5. There is a slight squeak when starting the engine, I believe this is from the fan belt (see point 2 above). Is this normal/expensive to fix?
6. The car front tyres seem to wear out every 3 years. Last MOT flagged advisory: "Offside Front inner edge Tyre worn close to the legal limit (4.1.E.1)." When i checked the tyre seemed fine though.
7. When the car is locked, the little fuel door can still be opened. Is this normal?
8. There is a lock button on the dashboard to lock all doors. When pressed you hear all doors lock and the red light on the button comes on. But the doors can still be opened from the inside. Dealer said it only prevents doors being opened from outside when you are in the car. Is this correct behaviour?
9. While test driving, I noticed it takes time to pick up speed. Specially if I switch quickly from 2nd to 3rd gear. I was finding it hard to get it above 20mph. Is this normal due to the small 1.2 engine?
10. They have following advisories from a fiat dealer check: Replacement door handles for back doors, front brake pads worn to 5mm (dealer said this was no issue as legal limit is 1.6mm ??). Front brakes lipped.
Dealer said they would get the tyre checked and the squeak looked at. But said their service would not have a receipt or stamp. I have to take their word they fixed it. They were dismissive about brakes advisory. Should I push for brakes to be fixed? Are they expensive to replace/fix?
Wanted your opinion and advice on above points. Thanks
