UnoCento:)
Hey...
Well basically in my car i have the following:
1 x 6 x 9 Pioneer 300w (80 w RMS) (Took other set out)
1 x XTC Split System 300 w (Dunoo what the RMS is)
1 x Vibe black air 12 1600w (550w RMS)
1 x 1000w Blaster 4 Ch Amp ( 4 x 250 w )
I blew my other amp (Not sure how but anyways) Im looking to buy an Amp that i could run my whole system off cause my 1000 w 4 ch wont handle all of the power.
My choices i picked out where as follows: (In My price range)
Targa TG-485 2000w 4channel Amp
- Peak power @ 4ohm 2000w
- RMS @ 4ohm 100w
- RMS @ 2ohm 200w
- RMS mono @ 4ohm 2 x 400w
- Dimensions 2.7" x 12.4" x 13.7" (H x W x L)
Targa MRV-F1005 2400watt 2channel amplifier
- 2x100rms
- 2x1200w max power
- 2 ohm stable
- bridgeable 1/2 channel mode
Starsound SSA-S-2600.4 2600w 4ch Digi Amplifier
2600watt 4 channel
- rms @ 4ohm 75w x 4
- rms @ 2ohm 125w x 4
- rms @ 4ohm mono 250w x 2ch
- 245mm x 58.5mm x 400mm (w x h x l)
Calibra CCE2400.4 Cyclops 2400w 4ch Amplifier
- Total Power: 2400w
- 600w x 4ch @ 4ohm
- 100w x 4ch @ 4ohm (RMS)
- 1200w x 2ch @ 4ohm (RMS)
- 200w x 2ch @ 4ohm (RMS)
- 125w x 4ch @ 2ohm (RMS)
Dimensions: 356x70x274mm
Audiobank 2400watt 4channel Amplifier
PAB-4520A
- 2400watt 4channel amplifier
- 100w rms @ 4ohm
- 150w rms @ 2ohms
- 600w mono rms
- 14.2 x 2.4 x 10.4 (inches)
NAB2950.2
Audiobank 2200watt 2channel amplifier
- 2ohms RMS Output: 290 x 2
- 4ohms RMS Output: 150 x 2
Maximum Output Power: 2200w
Bass Level Remote Control: yes
Dimensions: 273x56x380mm
What Sub Would do the best for my system??
Thanks so much
JW
- RMS @ 4ohm 100w
- RMS @ 2ohm 200w
- 2x100rms
- 2x1200w max power
- 2 ohm stable
2600watt 4 channel
- 600w x 4ch @ 4ohm
PAB-4520A
- 100w rms @ 4ohm
- 150w rms @ 2ohms
- 600w mono rms
NAB2950.2
Thanks so much
JW
