dtlove
Hi folks!
I've been having a few small problems with my 1.4 EVO GP recently, would love some advice on monitoring and some next steps.
1) Slow coolant loss - Have to top up the coolant tank ever 4/5 months with coolant as it slowly goes down, this has been happening since owning the car. Possibly down to bad seals on pipes, but maybe not.
2) Rough idle - Usually when sitting at lights, the revs seem okay but you can feel something isn't happy. HT leads look like they could do with replacement after checking, but anything else I could check?
3) Milky residue on oil cap and breather pipe - Only noticed today, and I do check this quite often. Some mild milky residue on oil cap, it wasn't thick sludge, and oil was changed a month ago. Car hasn't been doing long journeys recently, so I understand it could just be moisture build up, as this is the first time I've noticed this.
I know these are common head gasket failure symptoms, but I've had no loss of power or smoke blowing from the exhast.
Only recent work done on the car was timing belt/water pump replacement, about a week ago, mechanic did the road test with me in the passenger seat and we agreed everything was fine afterwards.
Any advice would be appreciated
