chrispetty
- Joined
- Feb 4, 2013
- Messages
- 1
- Points
- 1
i just bought a Mrk 2 punto and im not happy with the stereo/ speakers. so im wanting to upgrade them. im going to leave the standard tweeters in.
The door speakers im going for are a pair of
*goldblaster 4" Car Audio Speakers
2 x 400W max. power / 800W max. total output
Features:
1" (2.5cm) ASV voice coil
0.5" (1.5cm) neodymium tweeter
5.3 ounce (0.15kg) strontium magnet
Frequency response: 100Hz to 20kHz
SPL handling: 89dB
Dimensions:
4" (10cm) speakers
Depth: approx. 1.9" (4.8cm)
Hole spacing: approx. 4.5" (11.5cm)
Weight (each): approx. 0.9 pounds (400g)
the sub im going for is
*FLI Underground FU12 12" Car Sub Subwoofer 1000W
Power Handling:
Peak: 1000 watts
RMS: 300 watts
Min Input: 150 watts
Impedance: 4 ohm
Electroplated Injection Molded Polypropylene (IMPP) Cone
Butyl rubber surround for improved low frequency response
Spring loaded nickel plated terminals
Rubber gasket provides an airtight seal
Multi layer voice coil with black aluminum former
Frequency response: 25-1,500 Hz
Sensitivity: 86 dB
the amp im looking at is
*Auna AB-450 4-Channel Car Amplifier 2400W
Highlights:
4 (x 90W RMS power output up to 2400W max. In mono mode)
High-and low-level inputs
Adjustable low-pass filter (control range: 50 to 250Hz)
Features:
Connections: 2 x line level input, 2 x RCA stereo line input, 1 x stereo RCA output, 4 x screw terminals for speaker output
Adjustable gain
Frequency response: 20Hz to 20kHz
Signal to Noise Ratio:> 95dV
High level input sensitivity: 100 ohms
Low-level input sensitivity: 10 kOhm
Speaker impedance: 4 to 16 ohms
Included: 2x line input cable
Dimensions:
35 x 5 x 25.5 cm
Weight: approx. 2.1 kg
and the h/u im wanting is
*Kenwood KDC-4054UB CD/USB-Receiver
Playback - MP3, WMA, AAC formats
USB/Aux/Direct Ipod to connect external devices
1 RCA pre-out to connect additional equipment
High power 4x50watt built-in power amplifier iPod/iPhone direct control
FM & AM RDS Tuner
the thing is i dont have a clue about car stereo's. i know the mid ranage speakers will replace the standard door ones without stopping the window going all the way down thats about it but then again im probably wrong about that. im just wanting to know how to wire this in and if it would sound alright. any help would be very appreciated.
Features:
SPL handling: 89dB
Dimensions:
4" (10cm) speakers
Power Handling:
Peak: 1000 watts
RMS: 300 watts
Impedance: 4 ohm
Sensitivity: 86 dB
Highlights:
Features:
Adjustable gain
Dimensions:
35 x 5 x 25.5 cm
FM & AM RDS Tuner
