btmaldon
I know it needs choke when its cold but this 1988 45S needs it on full untill it warns up to at least quarter the way up the temp gage. Its a little embarrasing as it is reving the nuts off until I can put the choke back in.
There is no power without full choke until it has fully warmed up. Once it has reached temperature it still holds back a little (especially in third for some reason) but clears when I apply more gas. Its also fine when cruising at normal road speeds.
The car was off the road for 4 years and has only done about 50 miles since I restored it.
Its had new plugs and airfilter. Ive put Redex in the tank to try and clear it. Could it be a dirty carb, or do you recon it could be the ignition electrics?
Many thanks:worship:
