Technical needing some suggestions
k3vin
Walsall
hey everyone got a punto mk1 1999 got over 100,000 miles on the clock the last week or two seems to be knocking coming from all over the car if i put my foot down it knocks if i brake seems to judder when i change gear its the same as im coming of the clutch it knocks when i press the clutch down it knocks, it hasnt had a oil change scince ive had it and is quite low you rekon that could be the problem as it is isnt lubricating engine and that i just want to get it running smooth again as apart from that is a bang on car please help as im on a tight budget im on a 3 months work trial so basically need it running 2 get there. thanks alot
this is a load of ******** no one ever gets back to you on here:(!!!!
Well the fact is you said your car is low on oil and you not put any in since you had it basically means you are not putting effort in to try to solve it yourself so why should others help?
And I don't think you explained it well, what by knocking?
