Skyriders21
- Joined
- Jan 22, 2017
- Messages
- 4
- Points
- 1
Hello everyone,
First I apologize for my approximate English but I use Google Translation
4 days ago I had the delicate intention of wanting to change the 4 spark plugs of PANDA 900ie belonging to my uncle and not having rolled for ages ...
The first 3 plugs came very well but the 4th which is of course in a hard to reach place, well it broke after having forced like a deaf to try to extract it ...
In the end I find myself with a piece of spark plug thread that comes out of the cylinder head about 3 mm and everything else that got stuck inside including the ground electrode.
The porcelain part is out, so I have an orifice in which I attempted an extraction with stud extractor Facom and Hazet, with a lever arm of 1m50, nothing came, it is stuck of At stuck ....
I admit to having already appealed to a more generalist forum and I am offered enlarged modo 2 solutions:
Remove the cylinder head (I do not have the skills, I tried to find a tutorial, I found one on a site but that is too succinct for me with regard to my skills ... But this would seem to be the cleanest and most reasonable solution.
The other solution that seems hazardous would be to drill with metal drills 0.5 in 0.5 to use all or almost all the material and remove the remaining thin with pliers.
The risk is to screw the thread of the screw (but apparently recoverable with a repair kit including threaded insert and tap of M14X1,25) and to put full filings the combustion chamber. For that I had thought of a magnet on flexible arm with the help of a camera type endoscope to remove a maximum, but I do not know if the method is really viable or if it is more like a hacking that Is not going to be worth anything ...
I count on your help.
Thank you all and good weekend.
Tom '
Tom '
