Panda (Classic) My ZFA141A0004215562
I ll just add some Pictures to keep track of the progress and hopefully have a nice result in the end :)
Some info:
FIAT PANDA 4X4
Manufacture date: 01/01/1988
Engine type: 156A3.000 [999cc]
Miles on the clock: 895580
some pics
some more
Thanks mate :)
Today im going over to a friend to service it.
All belts, waterpump, filters and fresh oil in the engine and the box.
Water is leaking from the waterpump so i hope the new pump is gonna solve the problem.
We need to regulate the fuel in the carb because when on full throttle it chokes, i think the fuel is too much..
Other than that, if i have time today i will take off the front carpet and the seat to give them a wash + clean the car in the inside. I also need to clean the rear seats as they are in bad shape..
no work today but..................
(y) u guessed right.
the only place i have found rust is on both sunroofs on the metal structure.. its not serious but rust has eaten the corners and its falling into the interior when i open them :(
But for the car as a whole a lot of job has to be done.
Today we thoroughly inspected the car with a friend of mine...
Left front shock is shot.
Left hand steering rack needs to be replaced.
Both Gearbox bearings [not much damage but its in the list]
Several Water pipes needs replacing
Carburator Repair kit needed.
Belts/Water pump needed.
Clutch kit complete
Gearbox Oil & Engine Oil
Filters Air/Oil
Exhaust Backbox + support
Cam cover seal
and i broke the passengers window... so i will need one window mechanism...
i think 300EUR should do the trick.... hopefully :bang:
I do have a furry parcel shelf which is cracked :/ i have to reinforce it because it sags in the middle. i tried with a cable tracking plastic with double face but its not working :D i need to glue a rigid piece maybe metal with super glue or something.
My plastic one is all broke in the same place - keep it in place with pipe lagging foam to minimise rattlage :(
i bought a window mechanism for 5EUR out of an UNO but it doesnt fit... thus ill have to buy one specifically for the Panda ... grrrrrrrr money wasted on postages as its impossible to source one in Cyprus.
not so sunny these days but i tested some features :p
rear demister .. check
front heater / demister.. check
