A Anonymous Guest Sep 28, 2004 #1 my elec windows are soo slow does anyone knopw how i can fix it, they are ok going down but real slow going up
J jim Guest Sep 28, 2004 #2 mine are exactly the same and judging be previous posts i think a lot of people have this problem but i'm not sure why??? jim
OP OP A Anonymous Guest Sep 28, 2004 #3 Strip off the door cards as per the bravo guide then clean the runners, pray with a silicone based lubricant and also grease the spindle. Common fault with a common cause and a common rectification
OP OP A Anonymous Guest Sep 28, 2004 #4 No need to be so drastic, you can get them speeded up by spraying the runners that are visible without removing the covers - mine are much better now
A angie - B Guest Sep 28, 2004 #6 mine dont work at all, will doing what was said in this thread work for me as well?
OP OP A Anonymous Guest Sep 28, 2004 #7 Depends. If the motor is knackered then you will have to do the replacement as per the guide as well. Nige
