Don't thrash it. Just reset the ecu afterwards (or clear fault codes which will do the same thing)and then just drive normally -whatever that is -taking it up and down through the rev range and a bit of time on tickover as it needs to learn what normal is
Don't expect miracles to start with and it may make a mistake or two at idle whilst it's learning but hopefully it's now getting the data it needs in order for it to have a dog's chance of a tickover
You said in your post that the plugs "Are good and new" so I would guess they won't have aged much since 3 weeks ago
But yes - bad plugs -if they are- aren't good
