My roofs sagged!!!
My roofs sagged!!!
O
Ollie
I'm after someone who knows there **** about adhesives. My roofs sagged from the sunroof back. I need a glue to restick it up with. Who can suggest an ideal solution.
Ollie
mine hasn't sagged to much but with the system on it rattles and it does my head in so if how would you get the adesive in as im a bit worried about pulling things apart in my gorgeous bravo.
Sagged roof
When you open the boot, take off the seal that runs around the top of the boot. You can now access the gap between the roof and the roof material. That's how...
Ollie
Re: Sagged roof
something like a silicon sealant should do shouldent it ? i am assumeing you want something to stick the roof back on and not leave a nasty mark on there, well you would need a glue/sealand with no grease in it or water based i assume.
i have used silicon sealant in my car and on upholstry before and it has never leaked through or looked messy.
You need
You need a fabric glue.
Thought that would make sense really - Sylicone is not suitable as it would stain if it went through! I say IF!!
Dont try to bodge this job as it will cost u 1 hell of a lot if it goes wrong!!!
Kev
Re: You need
What you need to get is pressure sensitive tape, this is a clear double sided tape that bonds like glue without the mess and is an instant bond rather than waiting on a cureing time...don't ask me where you can buyit though...I manage to obtain it through a work related source if you know what I mean!!!
Re: Re: You need
Re the double sided tape - carpet fitters use it quite a lot!
Honestly!
Just a suggestion!
Re: Re: Re: You need
Yeah some fabric glue or double sided tape as the fabric is thin and the glue might show through.
Paul Maks
Used to use a syringe and clear Bostik, then hold lining in place with a clean old towel and a broomshank or similar to prop it up.
Pete
Re: Re: My roofs sagged!!!
RR- I ain't on about normal double sided tape, I'm talking about Pressure sensitive tape, stick absolutly anything together and will stay stuck!!
Saggy roof
Cheers peeps, much appreciated.
Been trying to get hold of some 'pressure sensitive tape', no luck so far.
Brilliant people, keep up the good advice
Ollie
F
7K
F1-ANG
F
K
2
1K
Dark Lurker
P
15
12K
Dark Lurker
A
578
anthony jenkinson
A
A
572
A
