Yes, and indeed my mate Paul is doing just that right now. I will be reporting back on progress once I've seen the work with my own eyes! All looks to be going together fine right now though.
He bought a written off 100HP and is putting that engine into the 4x4 in place of the original 1.2 8v. Lots of hairy wiring and ECU transplants, but it could be a very good alternative to the route I took for more power. And probably a lot cheaper. Maybe....
Would that bracket also fit the newer 69 hp 1.2 8v engine. ???The installation of the compressor was by TTS at Silverstone and they were excellent. The quality of their work is faultless and I have a fully CNC machined billet mounting bracket that looks 100% factory, matched to a billet machined pair of crank and s/c pulleys, running perfectly true, with the crank pulley machined for a perfect fit with the OEM crank pulley. It really is very professionally done.
Phil
Yes, but only if your car doesn't have A/C, as that's where the Rotrex sits.
Btw, if you ever want a go at fiddling with the 1.1 just give me shout![]()
Nope, no A/C in mine.
Is it posible to install the bracket and Rotrex without removing the engine from the car. ???
btw, sit the dynamo/alternator still on his own bracket and runs on the same belt as the Rotrex. ???
Oi! There's a Queue, you know!![]()
Had contact with Richard several time about a Rotrex kit but did not like the 5 figure price i had to pay for a complete development.TTS asked if I wanted to package the requisite bits as a kit, but I wasn't prepared to stump up the £££'s to have a batch made at the time. They will of course have the CAD drawings for my hardware and I am sure they'd run another off for a reasonable fee. Richard Albans (Mr TTS) and Darren his head Development guru are really nice guys and they are bound to be accommodating I'm sure. Mention my name if you speak to them (Phil Gardner).
Remember that I had a custom 4-2-1 manifold, 200CPSI CAT and stainless 50mm exhaust system built too, so I am unsure of the results if using the std manifold and pipe. For info, my Rotrex is a C15/16 - the smallest they did - but the first attempt with the C15/30 gave more mid-range but ultimately too much boost on std internals. Might have been ok with additional boost control, but that was too complex as I wanted Simple.
As it happens, I'm looking to install as recirculating dump valve, as there's a lot of air stalling when I lift off at high revs and I think it will be kinder on the Rotrex to remove some of the pneumatic shocks that happen when boost can't go anywhere on a slam-closed throttle It's an interesting science that still fascinates the hell out of me...!
