sweet fiesta (red one). I actually like the facelift lights, the old ones are very nice, and give the car *that* look, and the new ones give it a more bubbly look, which moving your plate down a bit enhances! if ONLY you didn't have to have a front plate it would look great
as for the bus scratch, i'm 95% sure you can get that out with some careful product choice and a couple of hours on your bum on the tarmac
hint..
sand the cracks, doesn't have to be mega neat, something like 1200grit wet and dry
touch up paint to fill in the holes, allow it to stand proud of the surface (little bit)..
allow at least 24hours to dry.
wash and dry area again, then very carefully wet 1200grit the raised bits of paint down to flush with existing paint.
then use a hard polish/'paint renovator' not t-cut. and a microfibre polish pad to work it in hard. repeat this stage quite a few times until the area (don't go too far into the good paintwork) is smooth and you can't see any marks in the clearcoat.
wash and dry area again to assess how its getting on.
if there is still pitting and lines then repeatt eh hard polish (gritty polish I mean).
if its smooth and just a bit hazey (will be quite hazy), then go onto..
a much finer polish, you want something like a finishing polish, or whatever you normally use. even AG SRP would do the job.
finish with a good paint sealent!
and the scratchs/marks should be gone, or near enough by hand, if you know a GOOD bloke with a machine polisher go to them and you will get better results. maybe cost you about £50
