General My blue GP 1.2
Standard GP 1.2
Lovely car, not overly slow
I have had most of the common problems associated with the car :-(
Although I am gradually during them out!
Did come with alloys, when I bought it, but took them off as they were not fiat alloys
Looking for a set of fiat alloys in the future!
Will add pictures as I change things
Thank you for the welcome
I agree aftermarket alloys are good & can make a car look great, but I don't think the previous owner worried too much about what specification wheel he put on!
The tyres fitted to the alloys are 195/50r15
As for modifications I am thinking of the following
Koni STR.T suspension kit
K&N panel filter
Exhaust
Tinted rear windows
Work currently required
Both rear for handedness to be replaced
Rear window regulator to be replaced
Front disc brakes & pads
Remove rear drums & inspect replace as required
I will be selling the old alloys/swapping
Ah I see, I was in search of some slightly bigger ones, What are the measurements?
Standard GP 1.2
Were abouts do you live if you don't mind me asking?
I have replaced the front disks & pads, birth rear door handles (easy thanks to the guide)
& the two parts in the picture attached, which are the standard aerial with the stubby abarth version & the airbox bracket so there's no more rattling under the bonnet :)
Next purchase will be the modified drain pipe 51810013!
I hope everyone is enjoying the sun :)
Just replaced the drain pipe with the modified drain pipe, a five minute job even with failing light.
I'll be interested in finding out how the new washer jets are in use?
The old drain pipe can be seen below.
I've just finished buying stuff from shop4parts see below
(S4P2355) Air Filter
(S4P3148) Door Mirror Glass - RH
(S4P3132) Tailgate Badge
(S4P2855) Front Washer Jet - LH
(S4P2854) Front Washer Jet - RH
(S4P435) Oil Filter
(S4P5380) Rear Window Regulator LH
(S4P2362) Spark Plug (x4)
(S4P8549) Top Suspension Mount
I'm going to be busy next week!
I have just fitted the new lh window regulator see below
(S4P5380) Rear Window Regulator LH from shop4parts
It feels quite graunchy & taught, should I use grease on the mechanism?
I will post pictures later of the broken one :(
This was an easy item to fit & replace, it doesn't have the same feel as an original part & the window winder handle fitment is a very hard press fit, but for £100 cheaper it's very good :)
